I am having some sync issues. I can sync data (sometimes) back to my phone (steps, sleep data), but I cannot change settings on my phone to sync to the Blaze (change the watchface, change the daily steps). My time was also incorrect. I have done the following:
Shutdown Blaze
Hard reset Blaze
Rebooted phone
Reset bluetooth connections to phone
Uninstalled and reinstalled fitbit app
Removed Blaze from fitbit account and re-set it up (that fixed the time issue)
Any other suggestion before I call fitbit for a replacement?
Best AnswerI'm having the same issue with a Galaxy S6 and Galaxy S6 Edge. The app can sync the steps and other things but I'm not able to change the watchface, set alarms or receive notifications. I hope that technical support can solve this asap.
Thank you very much for joining the Forums @Lockheede, @Drtallpaul76 and @Giovanny!
I'd like to take a closer look into this situation with the Blaze. Please answer the following questions:
Look forward to your replies so that I can find the best way to move forward.
