10-18-2017
03:58
20:28
EstuardoFitbit
10-18-2017
03:58
20:28
EstuardoFitbit
I cannot get my charge 2 to sync regularly. It randomly syncs once every few days. It will sync exercise and calories but not sleep or steps. No notifications work
I schedule a sync and it doesn't work
I have restarted phone, made sure Fitbit is charged, updated app. Forgotten pairing and re-paired with Fitbit. Nothing seems to work. Help please
Moderator Edit: Updated Subject For Clarity.
Hello @Rnaylor, good to see you have joined the Fitbit Community! I'm wondering which model of mobile device are you using? It is possible due to the syncing issues all the other features are failing since your tracker is not able to maintain an stable connection with your phone.
Make sure your phone is listed as supported in our list of compatible devices.
Also I was reading you have tried different solutions on your own. However I'm going to share with you the following post for you to review if there is an additional steps to try and for some requirements recommendations that may be helpful for this scenario: Having trouble syncing? (here's how to fix this).
See you soon and let me know how it goes.
