07-16-2018 11:54
07-16-2018 11:54
Since updating the app to 2.74.2 it does no longer sync to my fitbit versa. I have already reset the watch and reinstalled the app several times but it does not help.
When I reinstall the app it synches for a few times, but then seems to be stuck with syncing (loading bar pauses at about 10%) until I reinstall again.
The really weird part of this is, that the app most of the time shows the correct step count but does not safe it to the fitbit-website.
As I had no problems in the weeks before, this leaves the update to blame. Please fix this issue. Anyone else having synching problems since 2.74.x please join in, so that this matter is taken seriously.
07-16-2018 13:02
07-16-2018 18:21
07-16-2018 18:21
I am also having the same issue with my fitbit ionic. Starting this morning, my fitbit would no longer sync. I updated my app from the google play store to the latest version (2.74.2) and the problem still persists. I even tried removing the device from my fitbit account and pairing it again via bluetooth on my phone, but it could not detect it. The only way I was able to sync was through the app on my desktop computer, so therefore it must be an issue with the mobile app.
07-16-2018 18:52
07-16-2018 18:52
Same problem here, Nokia 6 Android 8.1, no sync whatsoever.
07-16-2018 22:47
07-16-2018 22:47
Having the same issues!!
07-17-2018 05:42
07-17-2018 05:42
Just a heads up: I went to the Bluetooth settings on my device and next to my Versa, I selected "forget". I then restarted the app and it worked. Not sure if it will work for you, but it is worth a try.
Best Answer07-17-2018 06:39
07-17-2018 06:39
Having the same issue.
Plus the detail that I tried to check the Wi-Fi settings and apparently it is off in my Versa and I don't manage anyhow to turn it on again.
And in the Wi-Fi settings of the app, it keeps loading infinitely and I get nothing.
Last time my Versa synced was one week ago 😕
07-17-2018 09:16
07-17-2018 09:16
Worked perfectly!! Thank you!
Best Answer07-17-2018 10:35
07-17-2018 10:35
Major syncing issues! Last synced 12Jul , Very stressful, unable to compete in challenges. Please resolve this issue ASAP.
07-18-2018 02:42
07-18-2018 02:42
Hi I had the same problem with my Versa and my Huawei P Smart but I feel I have sorted it. I unpaired from my Bluetooth on my phone and as long as it shows up on available devices when the Bluetooth is switched back on just then go into the Fitbit app and it should work!! I have had no problems with it as yet but it is only the second the day and it still works so I’m happy as it would work once set up but not after!! So simple really don’t pair it to your phones Bluetooth!!
Best Answer07-18-2018 06:38
07-18-2018 06:38
@SunsetRunner An interesting thought.. I just checked my Ionic and it doesn't show a pairing to the phone.. It syncs perfectly..
@SunsetRunner wrote:Hi I had the same problem with my Versa and my Huawei P Smart but I feel I have sorted it. I unpaired from my Bluetooth on my phone and as long as it shows up on available devices when the Bluetooth is switched back on just then go into the Fitbit app and it should work!! I have had no problems with it as yet but it is only the second the day and it still works so I’m happy as it would work once set up but not after!! So simple really don’t pair it to your phones Bluetooth!!
07-18-2018 06:48
07-18-2018 06:48
working again....thanks all
Best Answer07-18-2018 12:29
07-18-2018 12:29
Im having same issue since update. Done every step to fix multiple times but wont work.on occassion it will log steps and calories for the day but wont store to the next day and no activity ,sleep etc will log for a week now.
07-18-2018 14:28
07-18-2018 14:28
07-18-2018 14:29
07-18-2018 14:29
Best Answer07-18-2018 20:26
07-18-2018 20:26
Same issues. Hasnt sync'd in 4 days.
07-18-2018 20:43
07-18-2018 20:43
My Fitbit One is not syncing with any of my devices since Monday. Is it no longer supported by Fitbit? Is there nothing I can do to keep using my Fitbbit One?
Best Answer07-18-2018 21:06
07-18-2018 21:06
@SunsetRunnerIt has to be something else.. My Fitbit One always syncs to my non-compatible phone.. Quicker than the Ionic, probably because there is not as much data.
If your One has been working up until Monday.. What was the variable ?... the App Upgrade ?
@SunsetRunner wrote:My Fitbit One is not syncing with any of my devices since Monday. Is it no longer supported by Fitbit? Is there nothing I can do to keep using my Fitbbit One?
Best Answer07-18-2018 22:43
07-18-2018 22:43
Did it and it worked!
It synced all the past days and now it seems to be working again! Thanks ✌️
Best Answer07-18-2018 23:04
07-18-2018 23:04
@julianaabibiano Well done and what did you do?
Also Fitbit holds 7days of daily data and 23 days of summary data. Then the oldest day drops off.
@julianaabibiano wrote:Did it and it worked!
