Best AnswerWelcome to the Forums @MalHink! It's worth to double check if you have followed these syncing troubleshoots. Make sure that there isn't another bluetooth device that may be creating interference during the process.Setting up your tracker as a new device may also help you to bring it back to sync as usual. Also, make sure that your tracker is running the latest software version and your mobile device the latest version of the Fitbit app for iOs or Android device. You can also try to deactivate call notifications if they're turn on by doing the following: On the Fitbit app dashboard, tap your tracker, and then on the device screen, tap your tracker. Tap Allow notifications access and turn off access to the Fitbit Notification Service. Reboot your mobile device.
Hope this helps. Let me know the outcome.
