05-02-2020
13:56
19:34
RicardoFitbit
05-02-2020
13:56
19:34
RicardoFitbit
My Fitbit app won' t talk to my charge 2 if I turn my LG G6's Bluetooth off, then back on later. Then it takes days to get it to reconnect, numerous attempts and uninstall and reinstalls. Anyone have any advice?
19:34
10:14
05-03-2020
19:34
10:14
Hi @Chelle1100, welcome to the Community Forums!
First, I appreciate your effort and patience for troubleshooting this situation prior to posting. If you haven't already done so, I recommend you to check how the syncing procedure works here and see if there's a missing requirement on your Android mobile device that's preventing the syncing procedure to be completed.
Then, you can move forward to the troubleshooting steps that are specified on: Why won't my Fitbit device sync? and let me know how it goes.
Keep me posted, I'll be around if you need anything else.
