09-18-2017
15:09
05:27
RobertoME
09-18-2017
15:09
05:27
RobertoME
My blaze isn't syncing with my note8
Moderator Edit: Updated Subject For Clarity.
Best Answer09-20-2017 05:24
09-20-2017 05:24
Hello @SunsetRunner, good to see you around in the Fitbit Community! I was reading you are not able to sync with your Android device. Please give it a try to the suggestions @HelenaFitbit have shared here: Having trouble syncing? (here's how to fix this).
Hope this helps and see you until the next one!
Best Answer10-24-2017 19:46
10-24-2017 19:46
Same here but with the charge 2. Seems to be a compatibility issue with the note 8. Fitbit hasn't been responsive at all.
Best Answer11-01-2017 09:13 - edited 11-01-2017 09:42
Same issue here with my Note 8. I get a message that says "pairing rejected by Blaze" when I try to pair the devices together through Bluetooth. I tried all of the suggestions on the syncing issues page as well as well as turning location on and it's still giving me the same message.
Best Answer11-01-2017 10:58
11-01-2017 10:58
So I may have found a solution.
Go into the Blaze, and go to settings. Turn on Bluetooth Classic.
Go back to the Note 8, and let it scan. You should see Blaze and Blaze (Classic) come up.
Pair with Blaze (Classic). A passkey should come up on the Note 8 and the Blaze. Hit yes on the Blaze when it prompts.
I should note before all of this, I reset the tracker, restarted the phone and uninstalled and reinstalled the Fitbit app if that matters.
