10-22-2021
06:46
07:30
10-22-2021
06:46
07:30
My versa 2 wont sync up to my phone, when it does it then unsync itself and i can't sync it back up again. Im not sure what to do, any suggestions?
Best Answer10-23-2021 07:32 - edited 10-09-2024 08:25
Hi there, @Kat003. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2. I understand where your concern is coming from.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below:
1. Remove the Versa 2 from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa 2.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa 2.
