05-09-2019
06:34
13:49
RicardoFitbit
05-09-2019
06:34
13:49
RicardoFitbit
I purchased my versa last august, I think. It has worked fine until two weeks agi today. First the hear rate stopped working-followed all steps noted in forums and now works intermittently. But, at the same time after a 100% charge, it died within 6-8 hours. Have turned off everything and still drains in hours. Always lasted 4-5 days. Virtually useless now.
Not sure if heartrate working correctly because afraid of losing what little battery life it had. All issues started on 4/25/19.
Best Answer05-09-2019 14:47
05-09-2019 14:47
Just an update-fitbit support is excellent. Called support-they had me do a battery drain test today. Battery from 100% to 0 in under 8 hours. I called them vack with results and they are sending out a new Versa. Thank you Fitbit. While i would have preferred that my Versa continue to work properly, I am thankful for your quick assistance.
05-09-2019 14:47
05-09-2019 14:47
08-04-2020 09:00
08-04-2020 09:00
I have experienced the same drain on my versa. It started almost immediately as well, like it was affected by an update. I have turned off everything i can, rebooted the device, factory reset the device, changed to various clock styles (focusing on the Fitbit clocks) and it still drains from 100% to 0% with 8 hours. I have had this Versa since 8/2019.
