02-25-2019
03:23
06:12
LanuzaFitbit
02-25-2019
03:23
06:12
LanuzaFitbit
Can fit bit release a better firmware update to include the Samsung galaxy s7 edge phone. I have successfully paired my versa to my phone then after say a week, it looses the connection & I can never get it to reconnect.. The only way i can reconnect is to reset the versa back to factory setting prior to the firmware update & it connects fine... But its a constant loop... I will try one more time & if it stops then I will take the versa back for full refund as its so stressful trying for ages to connect.
Welcome to the Forums @SunsetRunner.
Thanks for bringing this up and sharing all of those steps that you have followed to get it to work.
In this case I'd recommend that you try these steps next time it happens:
Let me know if you have any further questions.
