Hi all,
Apologies if this has previously been answered, I did a quick search but didn't find an answer to my specific issue.
Walk is not currently showing as an activity on my Charge 2. I see in previous threads that you should be able to add Walk as and exercise shortcut using the Android App, however in my Android App (latest version) there is a list of activities but Walk does not appear there either.
My question is ... is there any difference with tracking a Walk as a Run (GPS Connected)?
If there is a difference, how do I add Walk to my Activity Shortcuts on my App ... so that I can then add it to my Charge 2?
Thanks in advance!
Charles
@ChubBBoy, in the app select the Account screen, then select the Charge 2 to open its Device Settings. Scroll down to Exercise Shortcuts and open the screen. There, you can have up to 7 Exercises - if you already have 7, and Walk is not one of them, remove one of the existing ones and add Walk. There is a "+" sign in the upper right hand corner that you select to add an exercise.
Thanks Larry!
That solved my problem and I was happy to see that Golf was also now an option ... time to get out my old clubs! ![]()
Charlie
