04-20-2018
06:31
07:02
RobertoME
04-20-2018
06:31
07:02
RobertoME
1 Go To Settings on Your Phone
2 Go To App & Notification
3 All Apps
4 Scroll To Fitbit App
5 Permission Toggle All On
6 Notifications - Make sure Toggle Is On , Make sure Enabled Sync Is on
7 Go to Battery
8 Choose Launch
9 Make Sure Automatically Is Toggled Off , Make sure In Manage Manually Auto Launch , Secondary Launch ,Run In Background Are All Toggled On
10 See if notifications work , You May Need to Restart Your Phone Once , Also You Can Turn Of Notifications Dots , And For Toast Notifications In Status Bar , Worked for me , Have been Getting Notifications for The Past 5 Hours , No Red Warning About Service Not Running , Still a Bit Of Delay in Getting a Notification But Least It's Working , Try It See If It Woks For You
Moderator Edit: Updated Subject For Clarity.
Hi there @Ta2man, thank you for visiting the Fitbit Community! I saw your post and I appreciate you have shared your workaround as a possible solution to sync Huawei Honor phones.
I'm sure this will help other users who are having troubles to pair the Fitbit tracker with these devices.
See you later and stay awesome.
