@Sparker18 I moved your post to the Android app forum, a better fit for your issue.
Laurie | Maryland
Best AnswerI am having the same problem from 2 days ago. Added same item around 80 times. How did you fix?
Best AnswerHappens to me sporadically to. I have noticed, that it happens more often on poor network connection. It seems there is an issue in the server communicating when adding food with bad network what can lead to several entries of the same item.
When it last occurs, my Wi-Fi was kinda unstable. I deactivated Wi-Fi on the phone during the logging and used my mobile phone internet. That works fine. After that I activated Wi-Fi again.
For testing purposes I restarted my router and could also add items without problems on the now stable Wi-Fi connection...
Greetings, Az
Best AnswerThank you so much. I definitely did this today. I also went back to the repeated entries and deleted them. We'll see if they come back.
