I dropped the aria 2 while cleaning. The glass on top is shattered but still on. Suspect I can use hot air to remove it and replace it but I can't find the glass anywhere as an orderable spare part. Can you please help? It would be ridiculous if breaking the glass would mean total write off. Thanks.
Best AnswerOk. That's very disappointing not to mention grossly unsustainable. Are there third party vendors? Like I said to throw a 130 USD product in the bin because a 5 USD pane of safety glass.
Best Answer@ErwinMul you'd have to do a search to find one, if it exists. If you have a glass and plastics type store, see if they could rig something up for you. Could be heavy duty plexiglass might work.
