Hi!
As many of the FitBit Aria users is seems that my unit has gone into "Step off - Sensing - Thinking - Error" mode.
I've read through the other similar threads, done the trouble shooting:
Remove one battery, wait 10 seconds, replace the battery, setup mode comes active and so on.
I've tried the same with fresh batteries.
Redone the setup process with both the web and the mac app.
Same result every time: Step off - Sensing - Thinking - Error
There have been no changes to my wifi network and I always use it bear footed.
I´ve even gone through the bother to remove all unknown devices that ever connected to my wifi router, just to be sure that I'd get a new network device, the aria, and guess what nothing happened.
This was done with the scales and computer both at less that a meter away from the wifi router.
it happened after i change batteries and the scale was working before I have changed the batteries
What can I do more?
Hi @Goekntten,
There's several different error messages that have been known to show on Aria scales, can you tell us exactly which one you see?
one cruise ship at a time!
