Aria 2 scale stopped syncing
My scale stopped connecting to the WiFi after I changed the SSID name. I reconnected and it says it connected but then gives me a "connection error".
Since the only thing that changed was the name of my wifi I decided it must be the issue. So my question is simply: can it not connect to a SSID with emojis? My wifi is called: 🐤🐤🐤:house:🐤🐤🐤
Or is the name too long because Unicode characters use more bytes?
I changed the name to plain text and it worked. (Well I changed the guest wifi to plain text).
Moderator edit: updated label
0 REPLIES 0
