Hi how are you? i cant get work the BMI, i restarted , make factory reset, try to join the aria by IOS, android, and always the same result, when appear the BMI, just put ?
i try a lot of things but nothing works, and in the dashboard appear BMI hidden, and i cant change it from the pc, or from the app, how i can fix this?
Best AnswerAre you sure you have the original Aria, not the more recent Aria Air?
The Aria Air does not measure body fat, therefore no BMI.
