10-20-2020
10:04
05:16
JuanJoFitbit
10-20-2020
10:04
05:16
JuanJoFitbit
***Wifi solution for early version of Aria***
Scroll down past the Aria 2 and Aria Air. The older version is lower in the list.
You have to set it up as a new device and the older ones will do this in Safari.
Remove and replace battery
Hold two bottom corners until Set Up appears
Choose Aria in your wifi network. This is temporary and it will work!!
Go through the steps and it is super easy once you know how.
There are no instructions for the older scales.
You got this!!
