01-03-2016
14:51
11:06
JuanJoFitbit
01-03-2016
14:51
11:06
JuanJoFitbit
I'm having trouble with my Aria always showing a low battery signal. I've replaced the batteries a couple of times and when I checked the power strip on the batteries themselves they show that they're at full.
The new batteries will provide power for a couple of days and then it will give me the no battery power error and the Aria won't power on.
Has anyone else had problems with this? I was hoping someone knew a fix so I wouldn't have to go through the trouble of getting it sent in.
Moderator edit: format
01-24-2019 10:04
01-24-2019 10:04
I am having that problem. It keeps showing the low battery sign even after replacing brand new batteries. I have contacted support and they said my 1 year warranty is up so i wouldnt be able to get any sort of replacement?
01-24-2019 11:23
01-24-2019 11:23
01-28-2019 03:55
01-28-2019 03:55
@jnguyen104 Welcome to our Fitbit forums! I'm sorry to hear that your Aria scale is experiencing the same issue and it's no longer under warranty. I know how frustrating this is for you. I really appreciate your feedback and comments since this helps us to keep improving.
@Hatter222 I'm so glad to hear that your Aria scale has been working great! Thank you for posting the update here!
01-28-2019
10:40
04:00
JuanJoFitbit
01-28-2019
10:40
04:00
JuanJoFitbit
Actually, my fix only lasted a few months. What would be helpful us to be
sble to order a replacement part.
Moderator edit: removed personal info
01-30-2019 03:59
01-30-2019 03:59
@grebewatcher I'm sorry about the experience you had with your Aria scale. I truly appreciate your feedback.
02-21-2019 05:06
02-21-2019 05:06
Thanks ,
I will try this. Cant hurt to try.
Will I lose all of the store data, though?
02-23-2019 06:41
02-23-2019 06:41
@tmatos Thank you for taking the time to try the troubleshooting steps shared previously. Regarding your question, you won't lose your data.
Don't hesitate to get back if you have any doubts!
06-11-2020 15:17
06-11-2020 15:17
Hi, I tried all that. Still seeing the Low Battery notification. And, unlike the others who wrote in here, I wasn't told I could get a replacement Aria Scale; which I'm dependent on. I'm retired. That scale is my lifeline that coordinates with my Fitbit one. And, I definitely don't want a Bluetooth only, app only device. I want my Aria 2 working properly. I don't know if Google has taken over but I really don't like that Fitbit has upset me to the point of tears even more than I am already being cooped up at home by not offering to replace my Aria scale when I have been a loyal customer and promoted Fitbit to others too.
03-18-2022 21:33
03-18-2022 21:33
I hate to admit it but I finally gave in after trying 8 new Duracell batteries and bought Energizer per someone on here’s suggestion - it worked! Have no clue why but if all else fails do try it! We almost junked the scale😏
03-23-2022 15:23
03-23-2022 15:23
Hi I am having same issue! Stays on all the time and drains the battery
03-23-2022 15:25
03-23-2022 15:25
I have same issue going through batteries like anything. Have cleaned contacts etc and everything. Looks like a common fault
03-23-2022 15:25
03-23-2022 15:25
Hi can you sort out my scales also pls as keeps draining battery like anything
03-24-2022 06:46
03-24-2022 06:46
