03-15-2017
00:33
14:53
03-15-2017
00:33
14:53
Hi, I moved my aria from one house to another, and connected it to the new home's network. All seemed fine.
However, my body fat went up overnight from 21.2% to 32.2%! Obviously that's not a genuine gain in body fat. The next day (today) it's at 31.7%
Historically in three previous houses, my body fat has fluctuated from mid-teens to early-twenties, in line with my weight at any given time, and never affected at all by move in location.
I always weigh naked, post shower (but dry) first thing in the morning.
Any ideas?
03-16-2017 06:17
03-16-2017 06:17
@Faux_punk It's great to have you aboard in our Fitbit Community! Seems odd that your body fat percentage has increased after you set up your Aria again. Please try taking the batteries out for 15 seconds and put them back in. Once this has been done, weigh yourself 5 consecutive times. After this, please check out if the body fat percentage gets corrected.
Keep me posted on the outcome my friend! ![]()
Best Answer03-20-2017 04:34
03-20-2017 04:34
Hiya, unfortunately that didn't work 😞
Best Answer03-21-2017 04:27
03-21-2017 04:27
@Faux_punk Thanks for getting back! I would like you to make sure of one more detail, please check out your profile settings and see if your height, weight and gender are correct. If the settings are correct, set up your scale as a new device and check out if your body fat percentage gets corrected.
Let me know how it goes my friend! ![]()
Best Answer03-21-2017 10:15
03-21-2017 10:15
I just setup my scale that worked for years on a new network, and the weight was fine but my % body fat went from 22.3 % to 35%, just like yours, wonder if it is something with Fitbit?? Thanks
Hank
03-23-2017 04:13
03-23-2017 04:13
@Polkimba Thanks for joining us in this thread and our Fitbit Community! So sorry to hear that your Aria scale is displaying inaccurate body fat percentage. I would like you to try the batteries workaround. Take them out for 15-20 seconds and put them back in. After you have done this, weigh yourself 5 times allowing 5 seconds between each measurement. This will re-calibrate your Aria scale.
I'll be around if any questions arise my friend! ![]()
Best Answer03-17-2018 15:39
03-17-2018 15:39
I've been reading the forums for some info and i bumped on this post.
I have exactly the same symptoms. After connecting to a new network body fat went up the roof !!!!
from a 17,5% to 19,2% from a day to the other.
I've already done the battery's workaround but obviously it didn't solve anything.
Any info on why is this happening and how can it be solved ?
Thanks
Best Answer07-12-2018 17:24
07-12-2018 17:24
Hi all,
I’m having thr same issue with body fat % inaccuracy, this happened after I change the Wifi Router and have to reset the Internet.
Please advise for a solution.
Thanks
Best Answer07-14-2018 11:23
07-14-2018 11:23
Hi every one and welcome to the forums @Mbatista! I'll be happy to follow up and help you to find a solution for the inaccurate body fat readings you've gotten from your Aria scale. If you haven't done so, please restart your scales by taking out the batteries for 15-20 seconds and put them back in. Once you've done this, weigh yourselves 5 times in a row in order to re-calibrate your scale and let me know if the issue gets fixed.
See you guys later! ![]()
07-14-2018 12:24
07-14-2018 12:24
Hi,
i’ve gave 2 chances to this procedure with any luck.
please advise
Best Answer07-23-2018 06:58
07-23-2018 06:58
@Mbatista Thank you for getting back and trying the troubleshooting steps shared above! Since the issue persists, I'll send your case to our Support team so they can investigate further and provide a solution. You should receive an email from them soon.
Let me know if you have any doubts! ![]()
Best Answer06-26-2019 04:57
06-26-2019 04:57
So I’m not seeing any follow up on this since the last post about sending those folks experiencing this an email. My scale has done exactly the same thing changing my body fat % by more than 10 percentage points. Obviously after more than three years at a relatively constant bfp, the change is something with the scale and related to reconnecting to the house network. Can the answers that were emailed please be posted here. I’ll take an email too but I’m sure there are others who could benefit from knowing how to correct the problem. Thank you!
06-26-2019 05:57
06-26-2019 05:57
Same issue with me.
Problem started with the WiFi password changed and reconnecting scale to the network. A few emails with tech support but with no results. I hope this helps to look for a solution.
MB
06-26-2019 06:32
06-26-2019 06:32
06-27-2019 05:24 - edited 06-27-2019 05:27
@JuanJoFitbit or anyone else @Fitbit, has this issue ever been addressed with a satisfactory solution? This thread is well over a year old and the original posters just responded indicating there has been virtually no follow up by FitBit. Definitely no solution has been offered. Please support your product and address this problem or let us know it’s time to punt.
06-27-2019 06:21
06-27-2019 06:21
06-30-2019 03:47
06-30-2019 03:47
@MrMadmario @Your description of the quality of tech support/customer service @fitbit is spot on! There has been woefully inadequate response to these questions and the problem has been raised by multiple customers. It’s truly unfortunate when a company passes up a golden opportunity to demonstrate their commitment to customer service and instead makes an obvious decision to ignore a problem with what? The hope it will just go away on its own.
Truly a disappointment Fitbit.
09-30-2020 19:10
09-30-2020 19:10
I just put my Aria on a new network and my body fat % increased 8% or so like the others? I have already taken the batteries out as was suggested to the others that did not work. It's sad this issue persists and that Fitbit does not care about their clients to resolve as old as this issue is
10-06-2020 16:27
10-06-2020 16:27
This has just happened to me too. Changed the battery and it asked me to re-connect to my wifi. Did this and a 10 + percentage point increase in body fat. This is after years of having a relatively stable and more believable figure.
Can we have an up to date response please Fitbit? Surely you have had time to investigate this issue
Thank you.
10-10-2020 21:26
10-10-2020 21:26
Same issue for me as well, my bfp was stable for several years in the high teens and suddenly doubled to over 35% overnight. It’s stayed at that level since then, for a few months now, through several battery replacements, and replacing an old Aria with a new Aria2.
Any update on potential reasons for this happening, or any resolution?
