04-26-2019
05:52
14:53
04-26-2019
05:52
14:53
Hi guys,
I have been using my Aria 1 for more two years but now I changed WiFi device and couldn’t connect so I made a reset to solve it but totally couldn’t not make the setup now , any advice please ?
thanks
04-29-2019 08:52
04-29-2019 08:52
I suspect that your new router does not meet the requirements that existed 4 years ago. Sadly, there is nothing that you can do to change that. Fitbit can't anticipate new technology years ahead and build that into their product when it didn't exist at the time. These are the router requirements:
Wireless 802.11b standard
WEP / WPA / WPA2 personal security
Automatic (DHCP) IP setup (static IP configuration not supported)
Also, it does not support 5GHz bands.
04-29-2019 13:37
04-29-2019 13:37
I don’t know why Fitbit couldn’t make a firmware update solution for it as most electronics problem are solved by that but anyhow thanks so much for your reply !
