Aria provides inaccurate body fat percentage
I purchased the Aria Scales a number of years ago, and have used them frequently (often daily) ever since.
I feel that the body fat percentage is significantly inaccurate. In the years since I’ve owned the scales, my body fat percentage hasn’t really ever changed, despite large amounts of weight loss following two pregnancies and visible changes in my body composition more recently due to training.
The scales have me sitting around 30% body fat, which is apparently classed as obese. I’ve lost weight recently and this has remained at 30%. I understand it is possible to lose muscle and body fat in equal amounts but I have now been strength training for over two years, and can visually see that I am currently holding more muscle than I did at the same weight in the past. Why do the scales not recognise any changes? Also why does the percentage seem inaccurate in the first place? I am 62.5kg and 169cm.
1 REPLY 1
BIA bodyfat measurement technology is +/- 11% as per many medical journal article studies. Unless you have a commercial unit that uses newer multi-frequency algorithms, the technology probably wouldn't be precise enough to reliably detect smaller changes.
Have you considered checking your bodyfat with DEXA or Hydrostatic Weighing instead? There is a reason why medical studies never use BIA and always go towards the "gold standard" of DEXA or Hydrostatic.
There's literally thousands of studies documenting the limitations. Here's an example of the detail if you're interested:
https://edepot.wur.nl/155745
