12-31-2024 12:35
12-31-2024 12:35
Haven't used my scale in months. Attempted to use and got "step off, thinking, err". App shows full batteries and last synced 12 hours ago. Did the pull battery and try again. No change. Did the weigh 5 times to recalibrate...no change. Attempted to remove and readd device and it fails the last step. After multiple tries now get a "wifi err" when attempting setup.
Best Answer01-05-2025 15:23
01-05-2025 15:23
What kind of device are you using to sync? I just after spending several hours got it to work.
Best Answer01-15-2025 14:34
01-15-2025 14:34
Enter your current weight on the app as a manual entry.
weigh yourself without bare feet a few times. It should eventually recognise you. Then weigh yourself with bare feet a few times to get a proper reading
