10-30-2021
15:00
10:43
DavideFitbit
10-30-2021
15:00
10:43
DavideFitbit
I've moved, lost a lot of weight, and although I can get the scale to weigh me as "guest," that's about it. How do I synch to my wifi, change my parameters and get it to transfer the data to my app? Or will I just need to manually enter my weight each time?
Best Answer11-12-2021 10:43
11-12-2021 10:43
Welcome to the Fitbit Community forums, @Kimchee001.
Thank you for sharing your inquiry about the Aria scale.
To set up and connect the Aria scale to your Wi-Fi network, make sure to follow all the steps listed here. To change your information or parameters, you should be able to see the scale listed and a device in your Fitbit account, Dashboard > Tap on your profile photo > Tap on your Aria scale.
After your Fitbit Aria or Fitbit Aria 2 is set up on your wireless network, it automatically syncs your stats to the Fitbit app after every weigh-in. After you see your measurements, you should see a checkmark, indicating that syncing is complete. You can then view your data on in the Fitbit app.
If you experience any inconvenience to sync your data, please make sure to check all the recommendations and requirements in this article.
I'll be around.
