08-24-2021
06:59
06:10
JuanJoFitbit
08-24-2021
06:59
06:10
JuanJoFitbit
My Aria last synced in April. I know how to synce my Versa 2 but not the scale.
08-24-2021 08:35
08-24-2021 08:35
Have you updated or replaced your wi-fi router? If so, it might not still be compatible with the original Aria scale.
Best Answer08-25-2021 05:49
08-25-2021 05:49
Yes I moved.
Best Answer08-25-2021 08:15
08-25-2021 08:15
The wifi standards have changed since the original Aria came out. I have seen that causing some to not be compatible with newer routers. I cannot be sure, but I suspect that is what happened with yours, especially if it stopped syncing right after your move.
Best Answer08-31-2021 04:25
08-31-2021 04:25
