04-03-2022 07:59
04-03-2022 07:59
How do I get up Fitbit Aria air to be able to see my BMI and body fat percentage on the scale?
Best Answer04-03-2022 08:53
04-03-2022 08:53
Aria Air does not measure body fat. I'm not sure, but thinking it does not display BMI either. You might see body fat & BMI faintly on the scale display, seemingly implying they should show, but I suspect that is just using a "canned" readily available part for the display. You can see BMI on the app, though it changes quite slowly.
Best Answer04-07-2022 07:42
04-07-2022 07:42
What makes it a smart scale then? Too much hype.
