01-18-2022 01:02
01-18-2022 01:02
Just purchased Aria Air ,find it so confusing ,step on it shows one weight ,step on again its a different weight. Doesn't show body fat and I can't seem to find how u get the BMI to show up either.Thinking of getting rid if I can't get it working properly 🤔 ,very disappointed in it so far ,can anyone help pls.
01-18-2022 06:31
01-18-2022 06:31
For one issue, Aria Air does not measure body fat.
As for BMI, I don't think it is supposed to display that either. Even though you might see what looks like a place to display it on the scale, I suspect that is just a stock display part that can be used to display it but does not for the Aria Air.
From the description in the Fitbit Store:
You can see a graph of your BMI on the phone app: From Today screen, tap Weight tile, then scroll right through the display charts at the top.
01-18-2022 06:31
01-18-2022 06:31
01-18-2022 09:05
01-18-2022 09:05
01-18-2022 09:26
01-18-2022 09:26
I've actually decided to send them back ,bitterly disappointed in them.
01-18-2022 09:58
01-18-2022 09:58
I'd like to see where you say it says it in the description. Obviously the quote I gave from the store say the opposite. Perhaps you were reading description of a different Aria scale, some of which have body fat, but not the Aria Air.
01-18-2022 10:15
01-18-2022 10:38
01-18-2022 10:38
Isn't that the same thing I posted? Are you saying that says it measures body fat and displays BMI on the scale? What I read is that does not mention body fat, and says syncs to phone where you can see BMI. I guess we interpret that differently.
