07-06-2015
06:18
07:09
JuanJoFitbit
07-06-2015
06:18
07:09
JuanJoFitbit
My Aria didn't sync for the last two days. Does it save data (like the fitbit trackers do)? Or is the daily data lost if it doesn't sync?
Thanks.
07-07-2015 06:24
07-07-2015 06:24
I'm happy to have you here in the Community @mcfloozy. It's awesome that you have an Aria scale at home, I bet it will help you very much.
To answer your question, your Aria will save up to 16 measurements (weight and BF% readings) if you are not able to sync it. After you sync, all of the information saved by the scale will transfer to your Dashboard.
Keep up the good work and let me know if you have any other questions.
07-07-2015 06:24
07-07-2015 06:24
07-07-2015 06:35
07-07-2015 06:35
Thanks! Exactly what I needed to know.
I love the way the Aria connects and makes awesome graphs for me. I've been a fitbit user since 2009, and I'm actually using more of the features now to support healthier habits. The Aria is a nice element that keeps the weight info accurate and honest.
Thanks for your answer. Loving the fitbit products.
07-07-2015 06:54 - edited 07-07-2015 06:55
09-14-2015 11:23
09-14-2015 11:23
That's interesting because mine hasn't been doing that. I lost internet without realizing it, and basically everything during that period failed to sync to my account.
09-15-2015 04:32
09-15-2015 04:32
Welcome @dhill9352. How many days did you go without syncing your Aria? Are you still missing weight or body fat readings from those days?
I look forward to your reply.
09-15-2015 07:00
09-15-2015 07:00
09-16-2015 04:46
09-16-2015 04:46
@dhill9352 That is awesome news! Please let me know if notice any other issue or difference in your Aria's performance, I'll be happy to further assist.
Have a great day!
04-29-2017 10:38
04-29-2017 10:38
Is there a way to get the Aria to attempt to transmit again or do I have to weigh in again, just to get that to happen?
05-02-2017 08:44
05-02-2017 08:44
@NomdelaNom Thanks for joining us in this thread and our Fitbit Community! I would like to follow up and would like to know more details about your question. Did you stop using your Aria and want to connect it to your network again? Is it experiencing a hard time when you try to weigh in and nothing appears on the display?
Looking forward to your response my friend!
05-02-2017 12:31
05-02-2017 12:31
05-03-2017 06:35
05-03-2017 06:35
@NomdelaNom Thanks for getting back and clarifying your question! To answer your question, you will need to weigh yourself again in order to check out if your Aria syncs properly.
Regarding the syncing issue, is there any error message on the display when you realized that the sync fails? Also, have you made changes to your network such as router, password or network settings?
Catch ya later my friend!
05-23-2018 19:59
05-23-2018 19:59
My Aria has been off wifi for 2 weeks. I just got it back on wifi now and even though I weighed myself once I was back online, all my weights from the past two weeks are not syncing but my current weight is syncing. Are the last 2 weeks of data lost? Thanks for your help.
05-26-2018 08:41
05-26-2018 08:41
@iakimura Welcome aboard to our Fitbit Community! I'm sorry to hear that your Aria scale didn't sync the weigh ins you took when your Aria was off WiFi. In order to avoid any confusion on my end, I would like to know if your Aria was completely disconnected from your WiFi. Did you change WiFi settings during those 2 weeks?
Looking forward to your response!
05-27-2018 13:37
05-27-2018 13:37
05-28-2018 08:19
05-28-2018 08:19
@iakimura Thank you for getting back! I believe that your Aria got disconnected from your WiFi since it asked you to set it up again. I totally understand that this is frustrating. However, you can manually log your weight for those days so you can have records on your Dashboard. You just need to go to your web-based Dashboard and click on the "Log" button (located at the top of the main page of your Dashboard). Then select the "Weight" and scroll down a little bit. You'll see an option to log your weight on different weights at the right side of the page.
Let me know if you have additional questions!
02-11-2019 05:34
02-11-2019 05:34
I had a similar problem where my aria was connected to an old WiFi network for a few days. I weighed in twice in that time and fixed the network immediately after the 2nd weigh in, but when it synced neither of them showed up and they are not even on the recent weigh in list. Are those lost forever?
02-12-2019 05:44
02-12-2019 05:44
@SarahCath Thank you for participating in our Fitbit Community! I'm sorry to hear that your weigh ins are not showing on your Dashboard. I would like to know a few details that will help me to determine the cause of the issue: Have you made changes to your old network (router settings or WiFi password)? Is your Aria showing any error message?
In the meantime, please restart and re-calibrate your scale by taking out the batteries for 15 seconds and put them back in. Once you've done this, weigh yourself 5 times in a row and see if your Aria syncs those readings properly.
Regarding your question, if your previous readings that didn't show nor synced, I'm afraid that they're can't be recovered. I'm sorry about this inconvenience.
Please keep me posted on the outcome!
05-19-2019 11:39
05-19-2019 11:39
I know this thread is a little old but I had a similar situation occur and thought this information would be useful to those looking for their data in the future. I had swapped out my router and decided to modify my SSID for WiFi. It was probably around 3-4 weeks before I remembered to reconfigure the Aria scale. Followed the protocol for reconfiguring the WiFi network on the scale (pull one of the batteries, press the bottom corners, etc. > well documented online) and once it had joined the new network, the data was all available. It had even retained the guest readings.
08-10-2020 12:53
08-10-2020 12:53
theoretically, this should be correct however, it does not work this way in reality. My measurements failed to sync selectively. It syncs 3 out of 5 measurements and then forgets about the missed measurements altogether. I am not doing any resets etc that will force delete those missed measurements.
