11-19-2020
05:57
13:34
LizzyFitbit
11-19-2020
05:57
13:34
LizzyFitbit
I went to use my Aria Air to do my regular weigh in and it would sync with my app, so I went to remove the device and re-add it when I got the 404 error. I’m not sure what to do.
11-23-2020 13:48
11-23-2020 13:48
Hi @StephEdWiens. Welcome to the Community.
Thanks for bringing this to my attention. It's odd that you're getting that error message when setting up the Aria Air. To investigate on my end, may I know the model and OS/software version of your phone? Have you tried using a different device to set up your scale?
In the meantime, let me recommend to try the following steps:
Restart your Aria Air:
On the back of the scale, touch and hold the button for 5 seconds. The display will flash oTA.
Touch and hold the button for another 5 seconds until the display shows clr.
I look forward to your response.
