01-24-2022 04:56
01-24-2022 04:56
Hi, I agree, the Aria is an embarrassment to Fitbit. It is not 5 years old and now I have tried a few days to reconnect it to the wifi. It does not work. How am I supposed to save the world if I have to throw away a good scale, just because Fitbit can not keep their older products supported?
On the landfill with the scale and another one, preferably without a battery is incoming.
01-24-2022 07:30
01-24-2022 07:30
If saving the world is your priority and biggest concern, you can still see your weight and log it manually each day. That might give you a sense that you are actually taking an action for the environment.
01-25-2022 08:57
01-25-2022 08:57
Mine is the aria 1 and mostly still works but I found it can’t connect to updated WiFi (5G). However most routers offer a dual bandwidth that allows you to reconnect the scale
