08-29-2021 19:25
08-29-2021 19:25
My Fitbit Aria is no longer syncing. It last synced in May 2021. I have the same router and wifi password as I did then, which is an Asus Zen WiFi AX (AT8) router. The only difference between now and then is that I moved. I still have the same ISP. I have the same modem. It first recognized the original wifi but could not sync the weight measurements, giving the "No Sync" error. I then tried to re-enter setup, and rejoin my wifi, but I keep getting the message "Joining WiFi - Linking - No Sync". And it fails. And now my Aria is stuck in setup mode, broadcasting an open wifi network. I've seen other people have the same problem since January 2021. Is there a solution to this issue? How do I fix it? Are there any firmware upgrades?
08-31-2021 16:13
08-31-2021 16:13
I have an original Aria purchased in 2015 that still looks brand new and has worked flawlessly until sometime last week. When I weighed in last week it calculated my weight and body fat like normal, so I didn't have any reason to wait for the sync confirmation. This past weekend while checking the app I noticed it wasn't recorded in my weight log, but I honestly thought it was just a fluke. Today I followed the same routine as usual except I waited for the confirmation check mark. Instead of a successful connection to Fitbit's server, I received the 'No Sync' message and verified in the app that it didn't transmit the information.
I have been a loyal Fitbit customer since 2015 and have owned two of every tracker model (2nd purchase of each model was for my partner), starting with the Charge HR up to the current version of the Sense. I truly hope there is a simple remedy that bubbles up from the forum, rather than having to go through customer service and deal with their infuriating and deliberately vague emails or chat. I almost walked away from Fitbit's entire ecosystem last year after exchanging 30+ emails that went in circles for a defective Charge 3. I also hope this syncing issue is not part of a deliberate plan to force obsolescence via a drip method for a product that doesn't have a comparable model in Fitbit's current lineup.
My internet service has been the same for the last 21 years and I've had the same cable modem and Wi-Fi router for the past 5 years. I haven't changed any configurations with the router or home structure either. In fact, the scale is always used in the same place I put it when I purchased it in 2015. It does make me nervous to see other recent posts regarding Aria sync issues, but I will wait to see what other potential solutions come from this great community. Thank you!
09-01-2021 20:49
09-01-2021 20:49
Thanks for your response. Sounds like you're having the same experience as me. I have a Charge 4 now, starting with a Charge and Flex. I got my Aria or maybe Aria 2 around 2017 and it worked great up until May, when I moved. I even changed routers and re-setup it up in 2020 which went smoothly, and the Aria continued to sync properly. So I find it very strange that a simple move with the same router and ISP causes this problem. It sounds like a bug in the software or firmware. I'm very surprised they haven't released any firmware upgrades, or let users factory reset the scales. I bought the Aria for the automatic syncing with a health app. Before that I frustratingly catalogued everything manually, which I don't want to do again. Have you found any solutions or come across any other forum posts of people who have fixes?
09-02-2021 17:37
09-02-2021 17:37
Interesting. I have had the Aria 2 for a few years now with the same ISP and it has worked FLAWLESSLY. In July, I took it with me while I was house sitting for a few days. It connected fine during my stay there, but when I came back to my place it couldn't connect. I reconnected and thought nothing of it. But now I literally have to reset the wifi on it every 2 or 3 days, because it stops syncing. It is infuriating. This was expensive and I purchased it as an investment in my health, and now I feel like they are deliberately bricking it on us. I hope there's a fix very soon.. I've been a loyal FitBit customer for a long time! 😔
09-04-2021 12:14
09-04-2021 12:14
I'm having the same problem with no assistance from anywhere.
09-05-2021 12:04
09-05-2021 12:04
I have spent the morning going through many of the posts in the Aria forum that appeared related to sync issues with either the original Aria or Aria 2. Although I did not see an apparent fix for those of us who have not changed their router or Wi-Fi credentials prior to the issue starting, I thought I would share a few other tidbits of information in case this applies to anyone new to this thread who isn't able to search the old posts.
The Aria uses older Wi-Fi protocols (b/g, 2.4 GHz band) so if you have a newish router that either has dual band (2.4/5 GHz) or single band 5GHz, the scale is not compatible with the 5GHz band or the newer protocols of n/ac/... For those of us who have dual band, several users found success by manually assigning the scale to the 2.4 band, our setting up the guest network function as a dedicated 2.4 band with a different SSID and pswd. Of course there are hundreds of different router models out there, so you will have to read the manual that applies to your model.
The Aria scales also use an older WPA security profile that is less secure than the more common WPA2 profile. My router has a setting to use both simultaneously so I can connect to legacy devices. The other twist is that the older scale technology doesn't support special characters or spaces in the SSID or pswd, so if you set up a guest network, only use alphanumeric characters. For those who found this to work, nobody can determine why their scale suddenly became temperamental to require this fix. Also, it may have to be repeated periodically to keep it synced properly which is another bizzare behavior.
The other popular method was to remove the scale from your account, and from the profile of any user set up to use the scale. You would then go back and add the device back in to your account following the normal setup instructions. However, be warned that some users found their scales suddenly caught in an endless loop that couldn't be stopped. Please consider the risks if your scale still measures properly since you can always manually enter your measurements manually in the app. This would basically make it a "dumb" scale since you paid for the privilege of doing the work yourself. Later tonight I will try to collect the links to the posts that I have mentioned here along with a few others.
On a side note, I noticed that in some of the earlier posts, a moderator named JuanJo appeared fairly responsive and active in the threads, but newer posts in 2020/21 have had ZERO representation from Fitbit. I also noticed that the views of posts are very high compared to actual comments posted, which suggests many more users are having isues that give up once they see the menagerie of ad-hoc fixes people have discovered on their own, not from Fitbit. As I mentioned in my previous post, I currently have a Sense, along with many other older Fitbit models, and with all the various problems the Sense continues to have since launching, moderator support is all over the threads trying to put out various fires. For me, this is the final aggravation that has convinced me to abandon Fitbit for good. I had already requested my entire data file a couple of months ago and have been setting up some Excel files to manage my data until I take some time to review the best option to import it with a new company. Loyalty to the customers who have been with them from their early days, and frankly allowed them to build the company to global prominence, means zilch to them now! Now they are only interested in monetizing your personal data, hence the purchase by Google.
09-05-2021 12:43
09-05-2021 12:43
Thanks for your response. This prompted me to check a few things and try again. My router is an Asus Zen Wifi AX Dual-band 2.4/5 GHz using WPA2-Personal auth. It used to work on this setup before. I thought about switching to a dedicated 2.4 GHz guest network, but I did a full factory reset of my router and re-tried the Aria setup. This time it managed to complete successfully. I also had to replace the batteries in the Aria to get it to register again, even though the battery level was at mid-level. It "seems" to have successfully synced during setup. I tested standing on it, and it also seems to have synced the new measurements. I will keep testing it over the next few days to see if it continues syncing. I do wonder if the lack of response from any official support is due to the Google purchase. Maybe they are still transitioning things between the two companies?
09-06-2021 06:51
09-06-2021 06:51
A few weeks ago I replaced the batteries and it worked well for about a week. Now I have to reset the wifi daily. The frustrating thing is that it DOES sync. So I know it works. It just seems to forget overnight. I don't have 10 minutes to waste every morning resetting the wifi on my scale 😒 I have bought 5 FitBits in total, and I'm really feeling like the company is just shrugging us off.
09-09-2021 14:39 - edited 09-09-2021 15:47
@coastalhues Your story is essentially identical to mine. I had a number of Surge trackers then a few Ionic trackers and now I have a Sense tracker. The Aria was given to me as a gift at the end of 2015 and I have been using it since. Linked it to a few different routers over the years and as of changing the batteries a few days ago it will no long sync and is stuck in setup mode. I've tried linking it to 2 different wifi routers and in each case it will link, but fails to "sync" I've been on the phone with tech support and we reached the brick wall pretty quickly. Nice enough woman, but after a blizzard of sorrys, I'm basically out of luck simply because I took more than 10 seconds to change the batteries for my scale.
I understand that the scale is 6 or so years old, but to have it working one day, and then not working after changing batteries with no explanation or help is not OK. The message is loud and clear from Fitbit: "We don't care about you."
The same thing happened with my Ionic where it was documented that the heart rate data was faulty and they offered no remedy. I likely would not have purchased another Fitbit device after that experience, but the Sense was given to me as a gift. I don't expect my technology to work perfectly. I understand that there will be bumps in the road. The problem is when the customer has to absorb all the bumps instead of the company.
I think I'm done with Fitbit. Now it is just a matter of finding the time and energy to find a better product. Or maybe just drop the whole tracking idea all together.
BTW, having owned a number of Google devices over the years, don't expect the customer service to get any more warm and fuzzy with them as the new owners. Google has no problem telling people: "sorry, you are out of luck".
09-10-2021 20:55
09-10-2021 20:55
I also have a original Aria scale that is not syncing to the computer. Tried resetting it but no result. What gives and how is this problem resolved?
09-13-2021 09:02
09-13-2021 09:02
UPDATE:
I had success getting my older Aria to sync. I took a few new steps and eventually it synced. This is going to sound crazy, but I think it had to do with clicking on a link at the right moment. Using my laptop to setup the scale at fitbit.com/scale/setup/start I went through the steps while watching my scale display and right when the scale switched from joining WiFi to linking with fitbit, I clicked on the "connected" button on the website.
Note: I had reached the "Success" page on the web before but the scale was still stuck in setup and I believe this is because I clicked on "connected" after the scale failed to sync. This time it took me to the "Success" page and my scale showed me the check mark as well. I stepped on the scale, it weighed me, recognized me and uploaded my data.
The other step that I tried was leaving the batteries out of the unit overnight, but I don't think that made a difference because I had another failed attempt before I thought to time my click on the "connected" button.
I would be interested to see if this works for anyone else.
09-13-2021 09:08
09-13-2021 09:08
We will see how long my scale continues to function. I don't hold high hopes, and this certainly doesn't absolve the company of criminally poor customer service. I'm still looking at a neat way to leave the ecosystem. I have been using myfitnesspal longer than fitbit and would be interested in hardware that could neatly track info and synchronize with myfitnesspal
09-15-2021 03:16
09-15-2021 03:16
I tried this and it worked. I was having the same issue as everyone else. However, after clicking on the connected button it still failed to actually connect on my phone screen but I stepped on the scale after exiting the page and the scale recognized me
09-16-2021 08:49
09-16-2021 08:49
@jivehonky Thanks for sharing your insights about your overall experience with Fitbit and your latest technique for establishing proper synchronization. I am glad you and @Mwin13 have a fully functional, at the moment, scale again!
I had already tried another suggestion I found that related to batteries and router proximity that worked for several users. I will include it here to give it a bump in case it works for someone else, and to add to your arsenal in case you lose connection to their servers again. This method involves positioning the scale as close as possible to your wireless router and switching each battery individually with a brand new one. The "trick" is to have the new battery in your hand so that you can swap it with the old one in just a few seconds to avoid triggering the auto setup function. However, the risk is that some folks who were a bit slow did trigger the setup function and could not get their scale to the point of weighing again as a "dumb" scale, essentially turning it into an expensive paperweight. Although you mentioned you left yours out overnight without any problems, it's impossible to predict who's might get stuck in a setup loop so others should consider the risk accordingly. The other point to mention is that users who were successful all had sufficient battery power showing in their dashboard, but the signal strength was apparently just below a minimum threshold that fresh ones helped overcome. This is also why you bring the scale to the router to minimize signal interference.
I am laughing at the thought of some users who are in our situation, finding this thread and reading all the bizarre solutions that have been discovered through trial and error. I was going to reset my router today and try the dedicated 2.4gHz guest network suggestion, but I will try your method first. It will save me a tremendous amount of time and aggravation if it works compared to the router reset/guest network method. If neither work, I think I will try hopping on one foot with the scale balanced on my head, wrapped head to toe in aluminum foil, while simultaneously throwing salt over my shoulder with my left hand and clicking connect with my right hand! Unfortunately, I can't try this method until midnight on the next full moon.
Jokes aside, I hope people recognize that the Fitbit community has been awesome in their efforts to help each other out, including here. Compared to other forums on this site for newer products, there has been scarce input from moderator experts on this increasingly common issue and zero official comments on what seems like some EOL scheme with the Aria. Even though we all understand products eventually become e-waste, the issues happening to perfectly good scales and my 7-month-old Sense, are unacceptable. Despite being a loyal customer almost from the beginning, I am done with the brand and actively looking at Garmin, Samsung and others. I will continue trying to fix my scale and would appreciate any suggestions for a comparable tracker and scale that work together in a new ecosystem.
09-19-2021 07:45
09-19-2021 07:45
For posterity, ErnstP's translation (via Google Translate)
Modern WLAN routers do not support the 802.11b WLAN standard. 802.11b was standardized in 1999 and does not support modern security technologies. Devices that only support the outdated 802.11b standard, e.g. Fitbit Aria WLAN scales, can therefore not be used together with modern routers with WLAN AX (Wi-Fi 6) and thus cannot establish a WLAN connection.
PMF (Protected Management Frames) encrypts the control information for the establishment and operation of WLAN connections and thus ensures more security. PMF is always active with WPA3 encryption and optional with WPA2 encryption. Some older WiFi devices cannot connect to WiFi when PMF is enabled.
Click on "WLAN" in the user interface of the WLAN router. In the WLAN menu, click Security.
Deactivate the option "Support for protected registrations of WLAN devices (PMF)" in the security settings.
Save / apply the settings.
09-28-2021 20:34
09-28-2021 20:34
Okay so I don't want to jynx it but.... I've gone a whole week without having to reset my wifi connection once! Are you ready for my solution? Are you sure?? I doubt you are....!
I switched to a higher performance battery. Changed out all 3 for a brand new set. Reset the wifi. Put my scale down. And haven't had an issue since.
Guys when I tell you I've tried everything.... I mean EVERYTHING. And I was still having to reset it every day or two. I tried changing batteries before too, but they were all the same brand. Logically I cannot explain how this has been a fix.... and maybe it's just temporary good luck on my part.... but try it. And report back. If it starts to fail again I will update!
Best Answer09-29-2021 14:28
09-29-2021 14:28
Best Answer10-11-2021 05:54
10-11-2021 05:54
Panasonic heavy duty. I honestly bought them at the dollar store.. I just went for the ones that said they were good in tech (gaming controllers, etc) instead of light household use. I always just assumed any crappy one would be fine since it's such a low drain device but... evidently not. 3 weeks in, I havent had to reset it once. I used to do it every day. 🤯
Best Answer10-11-2021 12:39
10-11-2021 12:39
