07-03-2023 14:45
07-03-2023 14:45
Where did all the guest weights go? All Past guest weights have disappeared and no new ones are visible?
Best Answer07-03-2023 14:50 - edited 07-03-2023 14:50
I think you switched your account to Google. Did this happen right after you switched?
Best Answer07-03-2023 15:05
07-03-2023 15:05
No. The guests weights (my husbands) all disappeared several weeks ago. I just switched to google 3 days ago in the hope to that would be the fix
07-03-2023 15:11
07-03-2023 15:11
Thanks for info; so can't blame it on that. Though that doesn't help you.
Best Answer07-04-2023 06:49
07-04-2023 06:49
@PamJCh Guest weights disappeared from the app some time in mid May. I think Fitbit did something to correct a long standing issue -- that weights aren't private. Guest weights go somewhere in cyberspace.
By removing the Guest weights, Fitbit created a different problem. What does a user do when their own scale says they're a Guest?
Laurie | Maryland
