08-09-2021
14:36
18:53
WilsonFitbit
08-09-2021
14:36
18:53
WilsonFitbit
how do i get my info on pc
Best Answer08-09-2021 15:11
08-09-2021 15:11
@shamarie,
Welcome to the community!
I assume that you're taking about the Fitbit Aria, have you paired it to your account?
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
08-11-2021 18:56 - edited 08-11-2021 18:57
Hello @shamarie. Welcome to the community forums! @PureEvil It's great to see you around and thanks for your input!
@shamarie If you haven't pair or set up your Fitbit Aria scale, I'd recommend visiting this help article for instructions: How do I set up my Fitbit device? Note that you will be able to find specific instructions for each scale model: Aria, Aria 2 or Aria ir.
You can also get additional information by visiting the product manual. On a side note, I've moved your post to the Aria Scales board to keep our forums organized.
Hope this helps.
