06-30-2019
15:07
08:45
06-30-2019
15:07
08:45
Guys, I recently had a minor link in my bathroom sink and some water got onto my Aria 2.
Initially it lit up (but display was faded) and now it wont turn on at all and there's condensation on the screen. Eek have I completely buggered it or can I still hold out hope?
Keen to hear from anyone who's experienced something similar and whether there are any tips or tricks to try to fix it.
Thanks heaps!
Moderator edit: format
06-30-2019 17:02
06-30-2019 17:02
07-01-2019
04:24
09:48
07-01-2019
04:24
09:48
@evemayam welcome to our Fitbit Community! I totally understand how frustrating this is for you since your Aria 2 shows condensation on the screen due to water contact.
You can go ahead and try the workaround that shared @Northern-Light. Also, take out the batteries and clean the batteries' compartment and contacts with a cotton swab to dry it out. Finally, try a new set of batteries and see if your Aria 2 gets back to life.
Keep me posted on the outcome! ![]()
Best Answer07-19-2021 15:34 - edited 07-19-2021 15:36
i have a water and aria problem too. i used your suggestion to dry the compartment and contacts. the aria now lights up and says "hi! sensing, sensing, sensing". every once in a while i see "step..." and then more sensing. i have stayed on the scale a good time. have i given up too soon? is there something wrong? i wonder whether i need to start all over as though it is a new scale. it has been a long time between the water event and my trying to bring it back to life.
also, i removed the fitbit software from my desktop computer while the aria wasn't working. the software kept opening when i booted up and i couldn't get rid of it.
if i do need to start over, how? it has been a long time since i bought the aria and i don't remember start-up.
thank you. i hope something works because i so like not having to write down my weight history with this scale.
07-20-2021
04:12
09:47
07-20-2021
04:12
09:47
@couldbe Thank you for joining us in this thread. Regarding the water damage that your scale experienced, I appreciate the time spent trying to get it resolved before contacting our forums.
Since the issue persists, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected and our Support team will be happy to follow up and assist you accordingly.
See you around.
Best Answer07-22-2021 11:14
07-22-2021 11:14
thank you.
04:18
09:48
07-24-2021
04:18
09:48
@couldbe You are very welcome!
As a side note, I'd like to invite you to visit our Discussions board, where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often! 😀
