03-05-2016
11:55
18:38
DavideFitbit
03-05-2016
11:55
18:38
DavideFitbit
How do I change from am to pm and vice versa on the alarm?
Moderator edit: format
Best AnswerThat's weird. Do you have the newest version of the app? When I click the app on my phone and then click Blaze twice, I go to silent alarms, then it allows me to set the time; right under where I set the time it has the option for am and pm.
Best AnswerDon't ask, but somehow i posted twice
Best AnswerOn the left is the app screen, the right has the web interface. Both set for PM. If you don't see this then remove the app from the phone amd install a fresh copy. After setting a sync will need to be done.
Best AnswerI'm hoping you have recieved a correct answer. However, when setting time, for the hours, there is 24 hour time on the inside. So you just click in the middle for times after noon. I hope this is helpful for others!
