Are there any Fitbit watches that have end consumer replaceable batteries that don't require product "surgery"?
Best AnswerHi @clintw there is no Fitbit that uses regular batteries. All the Fitbit watch style products require recharging and there are no batteries for replacement.
10-11-2021
13:58
10:59
10-11-2021
13:58
10:59
Welcome to the Fitbit Community, @clintw and thanks @Odyssey13 for the input.
@clintw The only Fitbit device with replaceable battery was Fitbit Zip but it was discontinued a few years ago. All of our devices have a non-replaceable battery inside the unit.
See you around.
Wow that is super disappointing from a sustainability point of view. Designed obsolescence via battery life is super annoying. If the only thing wrong with a device is that the battery, which is a consumable component (even if it is rechargable), it shouldn't require an entire new product.
10-12-2021
07:05
10:59
10-12-2021
07:05
10:59
Hi, @clintw.
Many electronic devices (wireless earphones, cellphones, smartwatches, etc.) are equipped with non-replaceable batteries as @Odyssey13 mentioned above. If you have a Fitbit device and need assistance with the battery (not charging or low life) you can always count with our Support team to receive assistance.
Have a nice day.
There was great uproar when cellphone companies decided to completely prevent users from replacing the battery - and it comes across as pretty circular logic to say that "since they all do it, we will do it too."
Your company IS contributing to the E-waste problem. It is the reason I will never buy another FitBit device. Good enough product, but short battery life = my dollars go elsewhere (like Garmin VivoFit 4, which DOES have replaceable batteries)
