11-10-2017 19:38
11-10-2017 19:38
11-11-2017 01:08
11-11-2017 01:08
That be wonderful
Feel free to add your vote / comment to @JohnBoyIIIJr 's suggestion, the more votes, the more likely the idea becomes real.
Feature Suggestions: New-Battery-Icon-for-Blaze-Percentage
12-22-2017 19:58
12-22-2017 19:58
I agree. I just upgraded from a Charge 2 to a Blaze. the Charge 2 had the feature showing a battery percentage on the display. I falsely assumed that a better fitbit would have this same feature. I may be forced to return my Blaze for my money back and reinstall my old Charge 2
Best Answer12-22-2017 20:00
12-22-2017 20:00
My Charge 2 has this feature. Why can't the more expenseive Blaze have it?
Best Answer12-22-2017 21:54
12-22-2017 21:54
When the red battery icon shows up on the clock face, I know it needs to be charged toning hr.
When I get an email, I know I should set some time aside to charge the unit.
Best Answer12-23-2017 10:30
12-23-2017 10:30
Best Answer12-23-2017 10:31
12-23-2017 10:31
That is true. However, on my Charge 2, I actually had a charge %age that I could scroll to and see when it was getting low. It is a feature on a less expensive fitbit and also on the Ionic, so it dhould not be difficult to do on the Blaze. I personally thi k it was a programming oversight.
Secondly, I do not always carry my charger if I gone a couple of days, but if I could see that I only have 30% less, I could either charge before I leave or pack the charger.
Thank you for your response
Best Answer12-23-2017 10:34
12-23-2017 10:34
you can see battery level if you swipe off the clock face to the side. and you can see the level on your phone in the app
Best Answer12-23-2017 19:46
12-23-2017 19:46
You are correct. I got my magnifying glass out, and I could see the small, very faint battery icon. On my Charge 2, the battery was bright, larger and has the remaining %-age as well. I guess I assumed that would be part of a more expensive device.
Thank you for your reply and making me aware that with the proper equipment, I can see a battery icon (without a percentage).
