04-05-2017
23:06
18:20
DavideFitbit
04-05-2017
23:06
18:20
DavideFitbit
in the process of seeting up new Blaze fitbit - battery too low to continue
Removed fitbit from band and inserted into charger - connected charger to power source
nothing happened - no battery icon on screen - just fitbit icon and fitbit.om/setup
what next?
04-05-2017 23:59
04-05-2017 23:59
@haggismuncher leave it on the charger for 30-60 minutes.
You can even continue the setup process while charging.
If you did a search, you would have found out that while the setup message is displayed, there will not be a battery icon. There will be a slight vibration while plugging the tracker in.
04-06-2017
04:52
08:10
04-06-2017
04:52
08:10
It's great to see you around @haggismuncher and @Rich_Laue thanks for stopping by.
As mentioned by our friend @Rich_Laue, once your tracker have the fitbit.om/setup icon it won't display the battery icon at the moment of plugging it in the charger. I recommend following these steps in order to paired your tracker from your Fitbit app:
I hope this helps, let me know the outcome.
04-06-2017 04:58
04-06-2017 04:58
thanks for your message but I have overcome the problem by changing the power source and it now seeems the battery is charged.
I have to say though that I find navigation within the app very unclear and difficult e.g I can only reurn to the home screen clock by shutting down and restarting. Its also not clear to me how I choose between the different clock faces?
04-06-2017 05:31
04-06-2017 05:31
just wanted to let you know that your advice to set the device from the dashboard has enabled me to get a handle on getting the best out of my fitbit blaze - including setting up the clockface and putting the activities in the preferred order. - thanks again
04-07-2017
04:03
08:10
04-07-2017
04:03
08:10
Those are great news @haggismuncher. I am glad to hear that your Blaze is now working properly. If you need anything else, do not hesitate in posting it.
Happy stepping.
