07-13-2017 15:35 - edited 09-20-2017 15:59
Fitbit Update: 09/3/2017
Our team is still actively investigating the root cause of this battery drain with Blaze and the Samsung Galaxy S8/S8+. I'm sorry that many of you are still having issues with a shorter battery life, but rest assured this is being looked at as high-priority for our team. My apologies for the inconvenience, and thank you all for your patience! I will provide an update as soon as there is more information available. In the meantime, please continue manually syncing your Blaze trackers only when needed. This will help preserve the battery-life.
Fitbit Update: 08/14/2017
Hi everybody!
Thanks for reporting your experiences with a rapid battery drain on Blaze trackers and your Android device - Samsung Galaxy S8/S8+. Our team is aware this is affecting Blaze users and they are investigating the root cause. I will update this thread when there is more information available.
As a temporary workaround, turn OFF "Always Connected" and the "All-Day sync" features. Make sure to manually sync your devices at least once a day.
Thanks for your patience!
08-20-2017 12:04
08-20-2017 12:04
Contact Help. They are doing their best to helo
08-20-2017 14:05
08-20-2017 14:05
I got this a couple of days ago from the Fitbit support:
With the link that you have provided, we can confirm that the person posted this updates is one of our moderators and Fitbit Community advocates which means this information is true. It looks like using the Bluetooth connection drains more the battery of your Blaze while using the Samsung S8/S8+. We are currently looking for the cause and we'll make sure to post updates on this thread once the issue has been corrected so keep an eye for updates.
08-20-2017 14:37
08-20-2017 14:37
Thanks for the info. I also notice that the app asks me to connect to Location so I can sync up my fitbit to the app. I didn't have to do that before either.
08-20-2017 18:23
08-20-2017 18:23
I have the same problem with my S8. Any updates on a solution
08-21-2017 07:58
08-21-2017 07:58
This workaround still does not increase battery life significantly. I'm using one alarm per day, encouragements for steps only three days per week, no linked notifications, but I do have auto heartrate. My S8 and Blaze are both less than a month old.
08-21-2017 08:34
08-21-2017 08:34
08-21-2017 08:34
08-21-2017 08:34
08-21-2017 08:55
08-21-2017 08:55
08-21-2017 08:55
08-21-2017 08:55
08-21-2017 09:18
08-21-2017 09:18
08-21-2017 09:18
08-21-2017 09:18
08-21-2017 12:10
08-21-2017 12:10
Completely defeats the purpose of turning off all the features. I might as well buy a $5 simple step counter. With that being said, will all the features off and no use...the charge only lasts about half a day.
Obviously some update or change within the last several weeks have affected battery performance. This should be looked at by Fitbit and addressed ASAP IMO.
08-21-2017 12:38
08-21-2017 12:38
08-21-2017 12:56
08-21-2017 12:56
08-21-2017 12:56
08-21-2017 12:56
08-21-2017 12:58
08-21-2017 12:58
Although convenient and perhaps reasonable to cite the S8's newer Bluetooth tech, you should be aware that every single other Bluetooth functionality that I have used before owning the S8 works perfectly fine. And not only does the Blaze connectivity flake out constantly, but just having the fitbit app installed while my Blaze is turned completely OFF makes any manner of Bluetooth streaming to another device completely unbearable with skips and dropouts. Remove the app and tracker from the equations, end everything works 100% fine.
08-21-2017 13:07
08-21-2017 13:07
How true @Vinny1014. I am surprised by how many people come in and say "I fixed the issue, I just turned off every feature that makes the product useful and now I am getting excellent battery life. Problem solved!"
At least it tells the time. Except of course, if you follow one of fitbit's battery saving tips, which is, no lie, to shut down the fitbit tracker when you are not "using it." So sure, I'll turn it off when I am at my desk (which, if I am really "using" my fitbit, I'd be leaving it on to give me a reminder to move, but I digress), but then an hour later I turn it on and the time has not advanced. So in order for the watch to work, or the silent alarms to go off at the right time (which I guess I am not using anyway because that was another recommendation from fitbit, to turn off those silent alarms), you have to sync up with Bluetooth. But of course, as is well documented here, it may take between a few and several tries to sync.
08-21-2017 13:10
08-21-2017 13:10
08-21-2017 18:52
08-21-2017 18:52
I was ready to put my blaze in the trash and get a new one...... So I'm posting in her to follow and see if it gets fixed
08-21-2017 19:15
08-21-2017 19:15
What's the point of having the blaze if you have to turn off all the features!?! Sorry but I refuse to do that and if a fix doesn't happen soon I'm going to smash the one I have and get a different brand!
