05-30-2019 19:17
05-30-2019 19:17
Battery usually lasts 4 days, over last couple of days it has lasted less than 8hrs, also it keeps vibrating with message 'All caught up no notifications' but I've switched device off for notifications - what has changed and what do I need to do to restore battery?
06-06-2019 15:25 - edited 06-06-2019 16:16
Hello @Hedgehog1, welcome to the Fitbit Community forums. Sorry for the delayed reply.
Thank you for the information provided about the Blaze not holding a charge or failing withing 8 hours. The battery of Fitbit Blaze can last up to 5 days; because battery life is affected by use and other settings, actual results may vary, but the duration should certainly not be of 8 hours.
Before considering other options, please make sure that you've followed the steps provided in this article: Can I improve my Fitbit device's battery life?
Please keep me posted on the outcome.
06-07-2019 18:33
06-07-2019 18:33
I am having the same issue. It started about the time my iPad Fitbit app updated. I have tried everything recommended to improve battery life and nothing is better.
06-08-2019 05:52
06-08-2019 05:52
Hi there, I tried everything Fitbit recommended, including removing all bits such that Blaze was little more than normal phone, not good! Then Fitbit help line recommended I reset Blaze by pressing middle left (back) button and bottom right buttons at same time until logo appeared = success and Blaze now back to normal, try it.
06-08-2019 19:21
06-08-2019 19:21
Thank you for confirming that you already tried the suggested troubleshooting steps @Jlpright .
I've gone ahead and sent your information to the Customer Support team for further assistance, so you should be getting a reply soon. If you haven't done so already, you may also try the steps that were helpful to @Hedgehog1.
Keep me posted on the outcome.
06-10-2019 08:37
06-10-2019 08:37
It seems a massive concern lately after Fitbit rolled out a new app and dashboard with horrendous bugs, complaints and even ads on the dashboard. Seems like someone at Fitbit isn't listening to all of thse bugs and all which appear to be self inflicted. Ive had my blaze for years with no problems. I'm now looking elsewhere
06-10-2019 12:22
06-10-2019 12:22
06-11-2019 15:46
06-11-2019 15:46
Hello @richmix, thank you for sharing your feedback about the Fitbit Blaze, I'm sorry to see that you've been having trouble with the battery life of the Blaze. Could you please confirm if you already exhausted all the troubleshooting steps mentioned here previously? If you continue to experience the same behavior, I can certainly send your information to Customer Support for further assistance. Please let me know.
Thank you for your help with this @Hedgehog1.
Keep me posted.
