11-04-2016 03:19
11-04-2016 03:19
Best Answer11-04-2016 03:57
11-04-2016 03:57
Hi
If not already done, feel free to check out the Fitbit Help Article:
URL: Click / Tap to go to the Fitbit Help Article 'My tracker's battery isn't charging'
How to clean the tracker? YouTube Video (By Craig) (For flex but similiar for other trackers)
http://www.youtube.com/watch?v=ezvXy9mKoGQ
Hope it helps
11-04-2016 04:42
11-04-2016 04:42
I just got my blaze a few days ago. I charged it fully last night and then put it back on before I went to sleep becuase I like the sleep timing function. When I woke up the battery is already on low. This is extremly disappointing. None of the features should be using that much battery that it drains that much in less then 8 hours.
11-04-2016 06:09
11-04-2016 06:09
Same here. Got my Blaze this week. Charge not lasting 48 hrs. My FitBit Charge lasted longer.
11-04-2016 07:28
11-04-2016 07:28
I had the surge before and even when running, it lasted longer then the Blaze! This is really frustrating.
Best Answer11-04-2016 12:15
11-04-2016 12:15
I got mine in June and it worked great until about a week ago. After going about 5 days without being charged it died (for the first time). Ever since then only lasted a day and now only holds a charge for 3 hours before dying, which obviously makes it totally unusable.
I'm starting to think that all fitbit products are total junk, I went through 2 Flex's, lost the first one because of the plastic peice that attaches it randomly falling off (like it always did) while it was at the store somewhere, On my second one I went through like 4 of the bands because they would either become discolored or break after a month.
Very disappointed...
Best Answer11-05-2016 05:13 - edited 11-05-2016 05:54
I don't have those issues though. Any of them.
I did however replace the stock charger with something from Amazon which allows me to not pop the tracker out when I need to charge it. This is directly plugged into my Xbox One for personal reasons, ie multiplayer death matches on GTA Online, or playing Prominence Poker. From the Low Battery Warning it'll take about 90 minutes minimum to charge up to full, 120 minutes max. The manual says between 60-120 minutes.
But if people are saying that their tracker lasts less than 5 days, that should be looked into. 4 if you have your phone going full tilt with all the notifications on.
Best Answer11-05-2016 22:27
11-05-2016 22:27
Best Answer11-05-2016 22:43
11-05-2016 22:43
Even with the new firmware I don't have that issue.
Best Answer11-06-2016 08:54
11-06-2016 08:54
THis is the exact same issue I'm having. I've tried shutting down all the features that are supposed to drain the battery, and I'm still having to charge this thing everyday. The last test I'm doing is charging it up to max and shutting it off. If the battery loses charge while turned off, this things going back to the store.
Best Answer11-06-2016 16:15 - edited 11-06-2016 16:16
I would, on the Blaze, go to settings - shutdown - tap - confirm, then press any button to turn it back on.
This will reset any stuck hardware
Best Answer11-07-2016 04:38
11-07-2016 04:38
Hello all, I hope you are doing fine.
I would like to know if you keep having problems with your Blaze's battery life? If you do, I recommend following the instructions provided here by our friends. If you have already tried those steps and keep having problems, feel free to get in touch with our support team, I know they will be glad to help since they have the proper tools to see your tracker's battery life. For a faster response you can contact them via phone or chat.
Let me know the outcome. ![]()
