I have a Fitbit Blaze ... it is about 20 months old... In the last week or so the battery doesn't seem to want to hold a charge... I fully charge it and in less than 24 hours the battery is in the red... I usually charged it up every other day and the battery would be at about the half way point...but now I have to plug it in every night... this is very frustrating... Is there a way to get the battery replaced ? I hope I don't have to buy a new one because the battery is bad...
Thanks
Best AnswerYeah, i think you should play the 'warranty' card. And, if you don't seem to have this card, you should call Fitbit support center. Fitbit response center is very responsive and usually replies within 24 hours. Hope you get your watch fix.
Best AnswerThanks I'll try that...I hope they will help..
Best AnswerOk we will see what they say..
