Battery
Having some major issues with the battery of the new blaze.  Initially couldnt get it to charge at all then it seemed to work okay but now I am having to charge daily which is really frustrating it cuts out in the middle of a workout when its not even red battery before starting.  I didnt even make it through 12 hours today and reportedly I had a full battery after charging overnight.  I initially contacted customer service and when they saw it charged well a time or two I was dismissed but I am now 2 months into this and continue to have intermittent issues.  Any tips?
4 REPLIES 4
Since the issue re-occurs, it's likely a battery issue @skpost
Feel free to contact the Fitbit Support Team (Click / Tap here to contact)
Optionally check out Returns & Warranty before contacting support.
Mention what you've already tried to speed things up.
Hi skpost,
I'd strongly suggest using a USB power supply with lower ampacity to charge Blaze's battery, for example the one of your smart phone instead that of, let's say, your tablet. Before the next carging process, reset your Blaze by holding the left button and the bottom right button until you see the Fitbit logo an Blaze's display.
Without going into detail, please try that first.
Regards,
Stefan
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Charge 6, Versa 4, Aria, Aria 2
So I use the cable they provided me with and it only works plugged into my computer versus into the wall. I tried the reset and I got about 36 hours out of my battery but that is with all the functions off- no messaging, no all day sync, and I didnt work out in this period so no active GPS for a run.  I feel this is still not acceptable for a battery that is brand new....
That really doesn't sound good. Smiley Sad
I'd suggest contacting Fitbit Support. I'm sure they'll find a way to make you a happy Blaze user in no time.
Reards,
Stefan
Stefan
