10-05-2016 00:48
10-05-2016 00:48
Best Answer10-05-2016 00:49
10-05-2016 00:49
Best Answer10-05-2016 02:45
10-05-2016 02:45
I don't have this issue on my phone. Syncs fine.
Best Answer10-05-2016 04:03 - edited 10-05-2016 04:04
Im having the same problem. I have Nexus 5x. Also, my alarm doesnt work anymore and it made me late to work.
Best Answer10-05-2016 04:34
10-05-2016 04:34
I had one last try before I left for work (maybe my 10th attempt to pair of the morning) and all of a sudden it worked. I didn't conciously do anything differently. I would be interested if anyone has any theories as to why it paired at this last attempt, but would not before.
Peter.
Best Answer10-05-2016 06:26
10-05-2016 06:26
Hi there guys @MrSausages @Sublight @Driver8666. Good to see you in the Community! 🙂
Sorry to hear you're having problems with your Blazes not syncing... I can recommend setting up your trackers as new devices. For that, make sure to first restart your trackers by pressing and holding the left and lower right buttons for 10-15 seconds. This will make the tracker to reboot and after that, you can proceed.
On you app, go to the Account section and look for the option that says "Set up a new device" and follow the on-screen instructions and after the tracker has been added back, it should sync properly.
Hope this helps. Let me know if you need more help!
