07-29-2017
01:32
13:43
DavideFitbit
07-29-2017
01:32
13:43
DavideFitbit
My battery is going flat continuously after 12-24 hours. How do I stop this from happening. Do I need to buy a new Blaze? I've had mine since they first bought them out in Australia
A restart (or two) is always a good first step. Hold left and bottom right buttons for about 10 seconds until the logo shows.
If that doesn't help, customer support might be able to take a behind the scenes look at your Blaze. Let them know you've tried restarting. Contact customer support here: http://help.fitbit.com/?cu=1
It's great to welcome you @Blazer01 and @Jrdubyakc thanks for stopping by.
I would like to know if you get in touch with our support team? If you have, did they offer you a solution for this inconvenience?
Hope to hear from you soon. ![]()
