10-14-2016 17:42
10-14-2016 17:42
Since I've had my Blaze, I've used both the Fitbit exercise mode and RunKeper to track my runs. The Fitbit has been on average .06 miles off, but it ranges from .06 to a worst of .23 miles per mile tonight. I start, the exercise in Fitbit, see it connect to GPS, then start both it and Runkeeper simultaneously.
Here's where it gets weird. Looking between RunKeeper and Fitbit, the maps are nearly identical. Tonight's run, measured by both my car and mapmywalk show as 1.1 miles. Runkeeper shows 1.09 and Fitbit shows .86. Again, the maps between the two apps are identical, but it's like Fitbit calculates distance incorrectly or something. Is this common, or something I'm doing wrong?
Best Answer10-15-2016 11:15
10-15-2016 11:15
This is super common. I get average of like 5-8 km off when im out jogging. Like last weeks run i had. Went out for a jogging on a rute of 6 km, the fitbit shows 11,25 km.
THe odd part. i Use google map log to get the real distance, fitbit use google map, and add 5250 meter extra for my run.
Best Answer10-16-2016 08:37 - edited 10-16-2016 08:40
Pretty annoying too. It's much easier to take a quick look at the wrist to check distance than fishing the phone out of the pouch. If it was at least consistent, I could work with that, but it seems to be all over the place. Even the same route. The night I posted the original message it came in at .86 miles. Three nights before the exact same route (same map result and everything) came in at 1.04. Seems there's no rhyme or reason.
10:43
08:07
11-13-2016
10:43
08:07
Hey there guys @Moebius01 @OleMarius. Good to see you in the Community!
Whenever it comes to GPS tracking, at least two dozen GPS satellites are constantly in orbit around the Earth and broadcasting data. All GPS devices, in this case, your Fitbit Phone which connects to your Fitbit Blaze, requires a direct path to these satellites in order to receive their radio transmissions. If the signal is being blocked—either because you're underground, near many tall buildings, or as a result of atmospheric effects—GPS will not work. Thus, whereas GPS gives you a more accurate measure of distance than step counting alone, the actual accuracy depends on both your environment and the weather. Keeping an eye on your sorroundings will help since in case you're sorrounded by a lot of trees or tall buildings, the tracking might vary.
Hope this helps. Let me know if you have any more questions.
11-13-2016 10:53
11-13-2016 10:53
11-14-2016 07:05
11-14-2016 07:05
@Moebius01 wrote:I start, the exercise in Fitbit, see it connect to GPS, then start both it and Runkeeper simultaneously.
@FerdinandFitbit the phone GPS is working fine, as Moebius01 is using Blaze and RunKeeper simultaneously and:
- RunKeeper: good mileage
- Fitbit Blaze: bad mileage
- maps are the same
This has been reported many times, and at least one Fitbit moderator has stated that its likely a problem with some loss of GPS data on Blaze because bluetooth was interrupted.
11-20-2016 04:57
11-20-2016 04:57
Thanks for the information @Moebius01 and @bbarrera. If at the moment of doing the exercise you have the wifi on, I recommend turning off wifi when you're using connected GPS to improve the experience. In this way your tracker might be able to register your miles correctly. You can also check the Things you can do to make the Blaze more accurate post, where our friend @bcalvanese is providing really good tips.
Let me know the outcome. ![]()
11-20-2016 16:22
11-20-2016 16:22
Best Answer02-12-2017 16:53
02-12-2017 16:53
It appears the problem appears because the connected GPS is used only for mapping while the distance/pace relies only on step detection. This shall be considered as a huge bug by Fitbit and hopefully next imminent firmware update will fix it.
I wonder if the issue was introduced only in the recent updates, I can`t verify it since I got by Blaze only 10 days ago but if this bug is not issued I will sell it straight away.
Best Answer02-12-2017 20:23
02-12-2017 20:23
I too have always experienced the same behaviour mentioned here although the difference for me is that in general the Blaze seems off by a consistent amount.
I also have a FitBit surge and that does seem to get the distance right. Generally over a 3km run I find the Blaze will record about 0.2 km short even though if I compare the map generated by the Surge vs the Blaze they show virtually identically. (haven't ever tried them on the same day as I don't trust them to sort out the double steps)
Given the margin is generally pretty small I haven't worried about it too much, although on the odd occasion it is worse.
02-13-2017 08:14
02-13-2017 08:14
Best Answer03-12-2017 05:31
03-12-2017 05:31
WOuld be lovly to see a software fix on the fitbit app for this. It is infact not about signal, amount of satelites. It is the software who is inacurate. Google Map is darn streight on the distance while Fitbit whom seem to use Google Map add extra distance. Blaze does not work, it is simple as that.
Best Answer04-27-2017 04:44
04-27-2017 04:44
@Moebius01 You are absolutely correct, it is the calculation used by FitBit which is incorrect. It can be proved by using FitBit's dataset and recalculating the distance.
Export your activity as a TCX
Use http://tcxtools.com/tcx/distance/ to recalculate the distance
Open it up in Notepad++ or similar, the recalculated distance is near the top
Best Answer04-27-2017 06:35
04-27-2017 06:35
@VikSteps mentioned this in another thread, just setup Fitbit-to-Strava sync to have connected-GPS runs/walks/rides sent to Strava, and you'll see accurate distance in Strava.
Best Answer04-28-2017 02:25
04-28-2017 02:25
@bbarrera Just for those following this thread, this was my reply:
That didn't work for me, Strava seems to trust the distance coming from FitBit, so overall distance is wrong but your segments are correct! If you had segments for the whole distance I bet the sum of those would be greater than the distance.
Due to a bug in Strava you cannot export the TCX from FitBit, fix the distance and re-import it with a new ID, it will ignore the distance and give you 0.0km, so you end up in a worse position! (segments still correct though)
Best Answer04-28-2017 14:14
04-28-2017 14:14
@VikSteps wrote:Due to a bug in Strava you cannot export the TCX from FitBit, fix the distance and re-import it with a new ID, it will ignore the distance and give you 0.0km, so you end up in a worse position! (segments still correct though)
I'm not seeing any Strava bug.
This morning I exported a TCX activity from Garmin bike computer, used the tcxtools website to "fix the distance," and import the new TCX file into Strava:
Best Answer06-13-2017 10:53
06-13-2017 10:53
Does anyone know if Fitbit has fixed this? Did the new update fix it? Blaze is not accurate on pace and distance when starting the activity from the Blaze. Customer service could not get it working correctly for me. Tried two different Pebbles. 25% inaccuracy is not useful.
Best Answer06-25-2017 05:26
06-25-2017 05:26
No it's not fixed it's consistently wrong.
Run's - it tends to go over, for me it's about 80-200m, not too much of a big deal
Bike rides - it is always under the distance, can be anything from 1k to 3k under
The underlying dataset seems to be ok, just the distance calculation is not!
Restarting the watch seems to get it closer to the real distance but this is not reliable at all, you're better off just using another app on your phone or getting a Garmin if accuracy is important.
Best Answer08-31-2017 07:53
08-31-2017 07:53
The blaze uses your phone gps in order to track the mileage. if your phone is on you, which it has to be in order for this function to work, and has a solid signal then shouldn't your fitbit blaze mileage match whatever the mileage tracked on your phone is? I ran last night with the intent to run 3 miles. I ran until my blaze reached that mark. I looked at my phone and my runkeeper app was at 2.75 miles. I was on a trail that goes around a wide open soccer field with very few trees and it was bright and sunny. The disappointing fact is that the blaze (which isn't especially "cheap") does not seem to keep signal with your phone - has nothing to do with satelites since the blaze doesn't directly have gps capabilities and uses your phones capabilities. This is doubly frustrating for those of us using it for training purposes.
Best Answer08-31-2017 09:26
08-31-2017 09:26
I was told the blaze doesn't use the phone to track distance. It use the phone only to map the route.
I've moved on to an Apple Watch Series 1. Its much more accurate than the Blaze in measuring distance and pace. The heart rate monitor is just as good. Battery life sucks, but the distance and pace accuracy is worth it.
