04-30-2018 07:55
04-30-2018 07:55
My heart rate display stopped working. I have tried to reboot several times, I have turned it off and back on several times, and nothing seems to fix it. Also I have noticed the battery is draining after only a day or two. This Blaze is only 2 and a half months old.
04-30-2018 12:56
04-30-2018 12:56
I had the battery draining issue on my Blaze I received for Christmas. I was sent a replacement but that one does not vibrate so I do not receive any of my notifications.
Best Answer05-10-2018 11:43
05-10-2018 11:43
A warm welcome to the Community @Ms1982 and @moonpie60! I appreciate the details you've mentioned. I'm sorry for the delay reply.
Regarding the display and battery draining issue you're experiencing, I would like you to make sure you've properly followed these steps: to restart it, and make sure you're properly charging it.
In regards to your tracker not vibrating, I would like you to restart it and try the other functions to check if it vibrates when getting an alarm or main goal.
Hope this helps! Keep me posted.
Best Answer05-16-2018 06:37
05-16-2018 06:37
I spoke with someone on yesterday and we went through all of the restarting options. It still worked sporadically with minimum vibration. A replacement should be on it way.
