Blaze Not Showing Map After Walk
Yes. When I go to the Fitbit app, my 250+ steps per hour shows from 6am-7pm.
Before the time change happened, it showed from 7am-8pm because I go to bed at 9:00pm and wake up at 7:00am. Went for a power walk with my dog, and there’s not enough data available and doesn’t show the map.Everything is great! Any advice from Fitbit Community?
I deleted the Fitbit app, reinstalled it, shut off my phone twice. Checked the time zone and it’s correct.
Moderator Edit: Updated Subject for Clarity
1 REPLY 1
@LadiesMan I hope you're doing well! I moved your post to the Blaze Board as there are more chances for you to get an answer to your inquiry here. I'm glad the Hourly Activity is showing correctly. Thanks for sharing the experience you had with your activity not showing maps.
In this case, did the Blaze show that it had connection to your phone's GPS when you started your walk? Please check this helpful article about how to track activities with GPS.
Hope this helps. Keep me posted! Smiley Happy
Santi | Community Moderator, Fitbit
Like my response? Vote for it! Also, accept as solution!
