10-25-2016 18:47
10-25-2016 18:47
Best Answer10-25-2016 21:59
10-25-2016 21:59
05:07
04:44
10-26-2016
05:07
04:44
Welcome to the Community @mdiet15 and @Aclobos thanks for stopping by. If you are having problems charging your Blaze, I recommend restarting your Blaze and after the restart process, clean the charging contacts on the back of your Fitbit Blaze, since over time the contacts can accumulate dirt and debris that prevents them from making a good connection to the charger. Use a toothpick or toothbrush to clean the charging contacts; do not scrape them with anything metal because this can damage the plating and result in corrosion.
I hope this helps, let me know the outcome. ![]()
11-13-2016 17:37
11-13-2016 17:37
Best Answer11-13-2016 17:42
11-13-2016 17:42
@mdiet15 If you bought it from Fitbit, you may still be covered under their one year warranty. Have you contacted support?
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
Best Answer11-13-2016 17:43
11-13-2016 17:43
Best Answer11-13-2016 17:48
11-13-2016 17:48
@mdiet15 I'd try contacting Fitbit support as I believe Best Buy is an authorized retailer for them. Can't hurt to give it a shot, and they may be able to help you. Let them know what all you have tried to help with the process.
Kelly | Oklahoma
Best Answer11-13-2016 19:49
11-13-2016 19:49
05:45
04:44
11-14-2016
05:45
04:44
Thanks for the information @mdiet15, @Kmransom123 and @Aclobos thanks for stopping by. If you have already tried all troubleshoot possible without success, feel free to get in touch with our support team, I know they will be glad to help. For a faster response you can contact them via chat or phone.
Catch you later. ![]()
