02-09-2017 05:32
02-09-2017 05:32
Just got it trying to set up & it low battery but went to charge & it will not get off the set up screen
Best Answer02-09-2017 06:21
02-09-2017 06:21
Hello @Kelkel81, have you gone through the setup procedure yet? This will need to be done before the setup screen disappears.
As for charging, did you feel a vibration when the Blaze was plugged in? If so, it is charging. There will not be any icon on the tracker showing the charging status until the tracker is setup.
For the setup help doc
Best Answer02-09-2017 16:44
02-09-2017 16:44
Hi @Kelkel81the thing with it is sometimes you have to click really hard
