06-19-2016 04:23
06-19-2016 04:23
08-08-2017 13:01
08-08-2017 13:01
Hi,
My blaze is not frozen but is stuck at the second screen that provides details of workout.
I tried resetting it by pressing the left and lower button but for no gain.
Not sure what the next step should be. My blaze is around 18 months old, is it close to it's lifetime? How long does a Fitbit blaze last? Is there a concept of warranty? Mine is gifted so have only the box with some UPC info.
any help will be much appreciated.
Amrit
08-08-2017 13:48
08-08-2017 13:48
08-08-2017 14:24
08-08-2017 14:24
01-15-2018 08:16
01-15-2018 08:16
thanks Rich, I was having this problem for the first time and your answer helped me a lot.
07-20-2018 11:58
07-20-2018 11:58
My blaze was frozen with a dark screen and the green lights flashing constantly. Thanks for the advice of holding the left and bottom right buttons for 15sec. It did the trick and all's good now.
11-06-2018 00:44
11-06-2018 00:44
Thanks, worked on mine. Never had this problem before and thought it was time to replace my Blaze!
11-06-2018 00:48
11-06-2018 00:48
11-13-2018 07:22
11-13-2018 07:22
my screen is frozen. I tried a reset and now I get the low batter screen. I started to recharge the battery but it's now stuck on the logo screen. no response to touch. I'm going to try charging it for an hour and check. looking for suggestions if that doesn't work.
11-13-2018 08:17
11-13-2018 08:17
11-14-2018 11:16
11-14-2018 11:16
That worked but now my BPM isn't tracking.
09-07-2019 16:38
09-07-2019 16:38
Mine is doing the same thing
09-07-2019 16:42
09-07-2019 16:42
Have you tried resetting it?
